cooling fan switch ?
Old Sep 22, 2010 | 09:23 PM
zz28jgallo's Avatar
if i take the cooling fan wire where it connects to the switch and ground it & the fans come on is the switch bad? other wise the fans dont come on
Old Sep 22, 2010 | 09:31 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: cooling fan switch ?
Originally Posted by zz28jgallo
is the switch bad?
Obviously seeing that is the only thing you have bypassed
Old Sep 23, 2010 | 12:39 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
yep
Old Sep 23, 2010 | 01:29 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Just make sure it's nothing silly like a bad connection where you hook the wire up to the fan switch.
Old Sep 23, 2010 | 03:15 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you can ground the connector to the block and the fans kick on, then the circuit and fans are fine. Clean the connector on the wire and the switch, and if that doesn't help, then your switch is bad. Done. NEXT!
Old Feb 1, 2011 | 08:46 PM
iroczcamaro87's Avatar
Car: '87 Iroc camaro
I had my fans grounded directly to the block and now they don't work. I changed the relays but the fans won't turn on. Could I have possibly blown the fan motor? I have the dual fan setup. I switched the fans and still a no go. What can be causing this problem? When I have the ignition on and ground and unground the fans I can hear the relay work.
Old Feb 8, 2011 | 08:56 PM
s4l's Avatar
s4l
Car: None atm :(
Engine: :(
Transmission: :(
Axle/Gears: :(
Why revive a nearly 4 month old, dead thread. Should have made a new one.
Old Feb 9, 2011 | 12:26 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fan Club
No.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) see if there is power on the pin E orange wire or red wire (depending on VIN) at the relay.
It doesn’t matter what position the ignition key is in.
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
