how much oil for 350?
Car: 91 camaroRS
Engine: 350 vortec
Transmission: 700r
just dropped my 350 crate motor and put in five quarts of oil but dip sick shows iam short & when i idle in drive the pressure shows its low on dash but when i let my foot of the gas its reads normal. WTF is going on here??????
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: how much oil for 350?
how much pressure do you have when hot, idling in gear?
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I dont trust stock guages. After taking all the stock stuff out and putting new electric Autometer guages in and having every guage read differently than stock 18 year old guages, I dont trust the stock stuff.
First thing I would do is to get a good mechanical oil pressure guage and hook it up to the port behind the intake manifold. See what it says. Your stock one may be right, but I would not trust it right away without confirming with another guage.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The dipstick is also a gauge. It's not always accurate. When someone always asks my how much oil something takes, I just say to the full mark on the dipstick.
As mentioned above, confirm the dash gauge with a mechanical gauge to see if they're the same reading.
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Do you have a stock oil pan? Or a extra capacity one with a stock oil pump?
Also, you are checking the oil level with the motor off and its sat for atleast 5 minutes or so to allow for drainback? Dont be offended by the question if you are checking it the right way, but I have had people check the level with the motor running and tell me they were low on oil.
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Oil capacity is also affected by oil filter choice. A WIX 1060 holds a 1/2 quart more than a 1065.
downsouthboy
Aug 29, 2015 11:29 AM
Eric-86sc
Aug 24, 2015 09:01 PM
Navy8125
Aug 21, 2015 09:32 AM
