Comp cam part number location?
Old Sep 24, 2010 | 09:09 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
So I got my cam out and I was trying to find out the part number but I cant seem to get a solid number. Where does Comp cam put their part number at?
Only clear thing I see is on the front which says ''280-H''
Old Sep 25, 2010 | 01:39 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Comp cam part number location?
280H is the grind number, that's the important part.
Old Sep 25, 2010 | 12:11 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
Ok, I was trying to figure out lift duration ect.
Are cams with a 280h grind number have the same specs or does it differ by model number?
Old Sep 25, 2010 | 01:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
As long as you stay within the same engine "family", two different cams with the same grind number should have the same specs. For example, a retro-roller cam, a factory-roller cam, and an LT1 cam will all have different part numbers, but the same duration, lift, LSA, etc.
Go to http://www.compcams.com/Company/CC/cam-specs/ and enter the grind number, then find your application in the list that comes up.
Old Sep 25, 2010 | 01:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
280H in a SBC should be a 12-212-2
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TreDeClaw
Aug 14, 2015 06:58 PM
armybyrd
Aug 10, 2015 09:23 PM
