manual gauge water temp
Old Sep 24, 2010 | 11:12 PM
Dwax13's Avatar
Car: 1986 Trans Am
Engine: Carbed 355
Transmission: Th700R4
Axle/Gears: 3.73 Posi
can someone explain where this goes on my engine? my stock water temp gauge does not work and i need to know how hot its running i have a 1986 trans am, it was a tpi working on carb swap.
Old Sep 24, 2010 | 11:36 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: manual gauge water temp
There's probably a nice place by the thermostat available for that, or possibly a plugged port in one of the heads.
Old Sep 25, 2010 | 12:05 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Find the factory temp gauge sender unit in the head ( single dk green wire ) and install the probe in its place
Old Sep 25, 2010 | 01:02 AM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Most likely on your driver side head or passenger side head. Be careful if you have coolant, it'll all come out once you pull either plugs out of the head. So try to be quick!
Bstrang6
Sep 8, 2015 04:29 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
