please help with omh meter on injectors
Old Oct 4, 2010 | 05:20 PM
mdihotmale's Avatar
Car: 1989 irocz,87irocz,05 tacoma trd
Engine: 5.7's,5.0.4.0
Transmission: a4, an sixspeed
so i replaced the cap rotor an wires today seemed to run better didnt stall after 2mins, ran for about 15 to 20mins then stalled an acts like it wants to start but wont, its 89 iroc 305 tune port, i tryd testing the ohms on the injectors tryd one an it was reading around 9 to 10 ohms while ideing, when i rev it it goes up to like 60 80?? anyone know the proper way to test them, an have any ideas how to get them damn little wires down into them so u can test them thanks
Old Oct 4, 2010 | 05:48 PM
mlynch001's Avatar
Car: 1985 El Camino SS, 2004 Trailblazer
Engine: Hybrid 305, 91 SD TPI, lots of mods
Transmission: 200-4R
Re: please help with omh meter on injectors
You cannot test injector resistance like that. You need to unplug the connector and use your ohm meter to test between the two pins of the injector itself. You should have 14-16 ohms on each good injector. TPIs' use high impedance injectors and the ECM cannot run "low" impedance injectors.
Old Oct 4, 2010 | 08:01 PM
mdihotmale's Avatar
update.... ok so i put new plugs wires rotor an cap in, car will now start an run , butsometimes shuts off randomly,an will sometimes not restart for ten mins or so an idle isnt as smooth as it should be, so idk im lost, then while sitting there ideling it the gauges on half the side when u turn the lights on dont work, an the buzzer sound will not go off, so i pulled fuse for gauges, im so lost with this, i pulled mass air flow sensor an ran worse, im ganna check all injectors 2marow an see if they are in spec, anyone else got any clues about gauges an why its running like this, thank you so much
Old Oct 4, 2010 | 08:09 PM
Brendan91Z's Avatar
Car: 1991 Camaro RS, 2013 Camaro SS 1LE
Axle/Gears: Stock
Injectors or Fuel Pump do what mlynch001 said and test the injectors... I had a similar problem and ended up replacing my fuel pump and injectors..
Old Oct 4, 2010 | 09:00 PM
mlynch001's Avatar
You may have chassis ground issues. . . make SURE that the wire harness ground to the intake is not rusted or broken. All ground straps in place (back of the heads to the firewall)? is the main battery cable ground tight. Is the body ground in place from the negative terminal to the fender. Are both battery terminals clean and tight? Are all the fuseable links on the starter hooked up and not burned up? Keep in mind, they can fail inside the insulation and still look good on the outside.
Check the fuse box and make sure that all the fuses are good AND that all the fuses have power on both sides when you turn the key to "on". You can check ATC type fuses with a test light by going through the top of the plastic fuse body to contact the small metal tab on either side of the top of the fuse. Look close and you will see what I mean.
You cannot start correcting performance issues until you have a reliable power supply and ground to the chassis.
Old Oct 4, 2010 | 10:35 PM
mdihotmale's Avatar
ok i was just out messing with it, keep in mind my gagues are out now, when car is off not running but key turned to on postion does not do the weird buzz noise when lights are turned on, but as soon as u start car it acts all weird an buzzer wont go off when lights are off.
i tryed to clean contacs on gauges an conectors on car an put gagues in an only left hand side sitting down only work, also car will run good for bit then like u turned key off it shuts off, doesnt really stumble or anythig, would bad fuel injectors cause the car to just shut off? thanks
Old Oct 4, 2010 | 10:49 PM
mlynch001's Avatar
That buzzer you are hearing is the "headlight on" warning. GM used a buzzer that came on when you turned the ignition off and left the headlights on. It sounds like the ignition switch may not be turning on all the way or have a bad circuit. Works like this, "Lights on" , "key on" NO BUZZER . . . "lights on" and "key off" Buzzer comes on.
The headlight buzzer does not know that the ignition switch is on. Look at the wiring diagram and you should be able to see which circuits are on and off with the key "on". The interconnection with the switch and buzzer should be easy to see. You could have a bad ignition switch or wiring.
Old Oct 5, 2010 | 02:36 PM
mdihotmale's Avatar
ok so three of my injectors are reading like 4 phms, all others are at 16.4 so id say i found the problem with the engine not running right, what a pain in the *** to get the injectors out, wow was not fun then damn tourqe bolts suck... so after i fix this hopefully i can fiure out whats going on with the gauges an stuff.
Old Oct 5, 2010 | 03:06 PM
mlynch001's Avatar
Use new o-rings on everything or you run a serious risk of fuel or vacuum leaks. It is a pain, but beats taking it apart three or four times over a few o-rings!
Old Oct 5, 2010 | 08:22 PM
mdihotmale's Avatar
for sure, can i go to napa an get new orings for the three injectors im changing?? an i found a iroc parts car with 145 speedo thats a direct plug an go right thanks....
Old Oct 8, 2010 | 11:33 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
If you can afford to do so, I'd advise getting all new injectors and replacing them all at once. If three of your injectors are failing the others are probably not that far behind. It's also time consuming to replace them. Do it all at once and be done with it.
Old Oct 8, 2010 | 04:49 PM
southbay08's Avatar
www.southbayfuelinjectors.com
info@southbayfuelinjectors.com
516-492-6504
92-Formula
Dec 12, 2015 10:34 PM
L98GTA87
Oct 19, 2015 10:43 PM
sahlomonic
Sep 20, 2015 07:15 PM
rubyred88
Sep 17, 2015 02:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
