heads/cam swap = crazy timing????
Old Oct 6, 2010 | 12:26 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
I did a head and cam swap on my engine. Now I'm reading 40 degrees advance at idle. Before the swap, I was reading about 13 degrees advance. I've checked, re-checked and quadruple checked the timing marks on the cam and crank gears. Valve lash. Everything. Any ideas on why its running so much advance? The engine is a BB 454 Gen VI with aluminum heads, hydraulic roller cam, and carbed. HEI ignition. It was running perfect before the swap.
Old Oct 6, 2010 | 01:41 PM
badmoon47's Avatar
Re: heads/cam swap = crazy timing????
Did you change harmonic balancers? Some have the timing mark at 12 o'clock instead of 2 o'clock for TDC which can make the timing seem WAY advanced. That happened to me and it took me weeks to figure out what had happened.
Old Oct 6, 2010 | 03:17 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
It sounds to me like the distributor housing/cap needs a clockwise rotation as viewed from above it until that 40 degrees is reduced to 13 degrees or am I missing something?
Old Oct 6, 2010 | 11:34 PM
steves1967's Avatar
When you swapped cams did you degree the cam or just install it straight up? Next question- are you 100% sure that the dots were lined up straight?
Old Oct 7, 2010 | 12:26 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Does the engine start okay? Too much advance will generally make an engine start hard. Are you running the same dist? Did you change the vacumm advance from ported to manifold vacuum? Check out your advance weights and springs.
Old Oct 7, 2010 | 02:07 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Did you just line marks up on the distributor and intake and now its 40 or will the motor only idle with 40? I'm kinda confused. Have you tried retiming the motor and setting it at 13?
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
jharrison5
Aug 19, 2015 05:53 PM
Fronzizzle
Aug 19, 2015 01:36 PM
