head gasketsw
Old Oct 6, 2010 | 08:10 PM
pestrada38's Avatar
Car: 1990 FORMULA WS6 T-TOPS
Transmission: BORG-WARNER T5
Axle/Gears: BORG-WARNER 3.42
head gasketsw
when do you know when you need new head gaskets or know when you blow one out?
Old Oct 7, 2010 | 12:39 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: head gasketsw
Taking the head off to inspect is the definitive way, but a leakdown test to find lost compression is a good idea, and coolant in the oil is a sign that something has to come apart.
Old Oct 11, 2010 | 04:07 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: head gasketsw
The most common type of head gasket failure is combustion chamber to coolant passage. The common symptom of this failure is sudden and severe overheating. We verify this type of head gasket failure by testing for HC either in the radiator or more commonly in the coolant reservoir. For this test I like to use my 4 gas analyser but you can also purchase a chemical test kit at the auto parts store. A severe cumbustion to coolant failure will create a steady stream of exhaust gas bubbles in the coolant reservoir. If you see this you need head gaskets.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
