Oil pump mounting bolt stripped.
Old Oct 8, 2010 | 08:12 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
The bolt that holds the oil pump to the bearing cap is stripped. The oil pump is stuck on the cap as the bolt will spin but wont pull up.
What are my options at this point?
Can I use another bearing cap from another block I have sitting around?
Both are mid '70s Chevy 350 4 bolt main blocks.
Old Oct 9, 2010 | 07:39 AM
Re: Oil pump mounting bolt stripped.
Can't really mix & match caps on blocks like that, as the caps and block are machined together. Doing that requires that the block be align-bored. Costs more than another block.
As common and cheeeep as those blocks are, unless you already have a bunch of money in machine work in it, you might as well just throw it away and use another.
I should also add: It may be possible to Heli-Coil it, depending on exactly why it's stripped. However, if it was because somebody gorilla'ed it at some point in its life or used the wrong bolt (too long) and bottomed it into the bearing & crank, it may already be so distorted that it's no good regardless.
Old Oct 10, 2010 | 03:55 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
exactly, see how bad the cap is. maybe you can helicoil it or install a thread insert. also look into using a ARP oil pump stud rather than a bolt, its less stress on the threads in the caps while torquing the fastener.
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Elliswon
Aug 10, 2015 12:33 PM
