Is this oil pump mis-machined?
Old Oct 10, 2010 | 02:26 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I bought a melling select, and the inlet ID for the oil pickup tube is .616" with a small step inside the inlet where the tube of the pickup presses in. Obviously they are a press fit, but the OD of the pickup tube itself at the pump is .622". That seems like a hell of a press fit to me. Seems like if I could provide enough force, it would split the pump body. What are the right IDs for the pump housing inlet bore?
Old Oct 10, 2010 | 02:42 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Is this oil pump mis-machined?
I think your best option is to email the mfg with this question.
Old Oct 10, 2010 | 05:33 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Actually, I just found a video from melling. It really is a .006" int. fit. So, its just a matter of using the tool and some hammering.
http://www.youtube.com/watch?v=KOIha...layer_embedded
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
