Help Me Put It Back Together
Old Oct 12, 2010 | 04:29 PM
Kolby's Avatar
Car: 1988 Trans Am GTA
Engine: 350 5.7
I'm not sure if this should be under general engine or TPI. I apologize if it is in the wrong spot and for the horrible quality of the photos which were taken with my phone. These questions are likely very simple and I would appreciate the help.
ta1.jpg?t=1286918398
I know the right most one if for my transmission fluid stick. What is the left one? What hose goes to it? It feels really loose as though it could be pulled out even though it wont.
ta2.jpg?t=1286918571
What goes here?
ta3.jpg?t=1286918704
Passenger valve cover. What goes in the grommet and what does the other end go to?
ta4.jpg?t=1286918757
Drivers side valve cover. After I swapped them out, the stock oil cap wouldn't fit so bought a different style cap which didn't fit either. Is the cap supposed to go in the right or left hole? Also, I believe which ever hole the cap doesn't go in, a grommet goes in as well as a hose. Where does the end of the hose go?
If you need to know, the engine is a 5.7 in a 1988 GTA.
I really appreciate any help!
Old Oct 13, 2010 | 01:24 PM
corey13's Avatar
Car: 88 camaro
Engine: 5.7
Re: Help Me Put It Back Together
in the first picture is that the hose for the smog control stuff that goes from one manifold to the other, it should be a hardline that runs over the bellhousing right behingd the motor, if it is, you can probably just take it out, since you dont have the other one and your not using it. sorry if thats not it.
in picture three you can put a crankcase breather filter on there.
in picture four, the oil fill cap goes on the back hole, and the front hole i believe should have a pcv valve in it.
i have very similar (if not the same) valve covers and thats how mine are hooked up.
Old Oct 13, 2010 | 01:30 PM
Kolby's Avatar
Engine: 350 5.7
Thanks! I hope that is for smog control. I would like to just take it out but its not coming. What does the other side of the hose that goes to the pcv vale go to?
Old Oct 17, 2010 | 11:30 PM
Kolby's Avatar
Engine: 350 5.7
Nobody knows what the other end of the hose connects to?
Old Oct 18, 2010 | 02:08 AM
90vertiroc's Avatar
Car: 1990 IROC vert
Transmission: 700-R4
It goes to the vacuum port, under the plentum.
Old Oct 18, 2010 | 03:00 AM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
It looks like you have a TPI. The crankcase breather can have a filter on it or you need to run a hose from it to the Throttle body (Thats the hole in the passenger side valve cover). If you just use a breather then you need to plug the hole on the throttle body. The PCV needs to go into the drivers side valve cover and have a hose from the valve to the plenum like 90vertiroc said. It really doesn't matter which hole you use for what on the drivers side, but in stock form the oil filler is closest to the firewall and the PCV is closest to the front of car like corey13 said. The pipes all over the place are for the smog system. If you remove them then you have to plug the holes in the manifolds. Some people just cap the tubes.
This shows the Crankcase and PCV routes.
As far as smog stuff, cap the manifolds and cut off the pipe at catalytic converter and cap it or weld it shut. Check the following for help removing.
https://www.thirdgen.org/forums/tech-general-engine/582993-smog-removal.html
https://www.thirdgen.org/forums/tech-general-engine/575113-air-components-removal.html
https://www.thirdgen.org/forums/tech-general-engine/568196-lets-talk-emissions-equipment.html
Old Oct 20, 2010 | 02:49 PM
Kolby's Avatar
Engine: 350 5.7
Awesome! Thanks so much guys!
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Leggman1
Aug 6, 2015 04:15 AM
