2.8 no start
Old Oct 18, 2010 | 04:34 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
2.8 no start
I had this car running back in july, i replaced the fuel pump and a FPR vacum line and she started right up, it ran for a week then died and wont start, so far iv replaced the ign module, cap, button, entire fuel rail system, fuel pump,and MAF sensor. after i changed the fuel system i checked my timing and i was off two teeth so i set it back to normal and tried to start it and it was back firing so i swapped plugs 1 and 4and its fireing now but wont start, my plugs arent fowled, they are newish, along with the plugs, and im lost, can someone please input, i have plenty of pressure at the rail because when i push in on the nipple the gas almost hits the hood. someone please help me!
Old Oct 18, 2010 | 05:41 PM
Engine: L31 350
Re: 2.8 no start
help please
Old Oct 18, 2010 | 08:41 PM
Engine: L31 350
Re: 2.8 no start
anyone?
Old Oct 18, 2010 | 08:46 PM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Re: 2.8 no start
What do you mean "two teeth"?
Old Oct 18, 2010 | 08:48 PM
jwande's Avatar
Engine: 305 TBI
Re: 2.8 no start
Coils can fire but not strong enough to start the car. Test the coil.
Old Oct 18, 2010 | 09:06 PM
Engine: L31 350
Re: 2.8 no start
thank you!! i will test this in the morning!!
Old Oct 19, 2010 | 08:42 AM
Engine: L31 350
Re: 2.8 no start
would do i test the coil?
Old Oct 19, 2010 | 08:52 AM
Engine: L31 350
Re: 2.8 no start
might also add that im getting fuel and spark and its fireing but just not enough to get it to start, my dad is bringing it up to TDC then doing a compression stroke today then hes gonna check the timing to see where im at. this is really starting to kill me.
Old Oct 19, 2010 | 06:19 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 2.8 no start
Remember you have to disconnect the DST connector when setting base timing. I wouldnt fool with that until you can atleast get it running
Borrow a fuel pressure gauge and make sure it's building pressure. Next, double check your firing order. Its easy to get the wires mixed up
Old Oct 19, 2010 | 06:44 PM
Engine: L31 350
Re: 2.8 no start
whats a DST? and i have a fuel pressure gauge here i plan on checking that tomorrow.
Old Oct 19, 2010 | 07:18 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 2.8 no start
http://www.austinthirdgen.org/mkport...tachometer.jpg
Lower right part of the schematic. Its for a 90-92 car, but your 86 will have it too
Old Oct 19, 2010 | 07:22 PM
Engine: L31 350
Re: 2.8 no start
im not seeing it jon.
Old Oct 19, 2010 | 07:29 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: 2.8 no start
its a connector right by your heater box(might be in the wire loom) its a gray plastic connector with i think a white wire coming out of both ends(may be wrong on the color) you have to unplug this to set base timing
edit...correction tan wire
Old Oct 19, 2010 | 07:34 PM
Engine: L31 350
Re: 2.8 no start
thanks, if i dont figure this out soon im gonna pay someone on here to come and look at it for me and see if they can help me
Old Oct 19, 2010 | 07:51 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 2.8 no start
Tan/blk wire, single pin black inline connector
Old Oct 21, 2010 | 06:01 PM
Engine: L31 350
Re: 2.8 no start
got it running and its running great too, my dizzy was off and so was my spark plugs, my step dad had them wrong but its all good now, thank you everyone for your help!!!!
Old Oct 21, 2010 | 06:07 PM
Pillsbry10's Avatar
Re: 2.8 no start
haha i swore my plugs were right too....always double check that kids i screw it up constently for some reason
Old Oct 21, 2010 | 06:12 PM
Engine: L31 350
Re: 2.8 no start
well on the passenger side my step dad thought they ran 123, then the driver side picked up with 456, insted of it being factory 1, passenger, 2 driver, ect, i didnt know he changed it.
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86Base
Aug 8, 2015 01:34 PM
