Oil leak
Old Oct 20, 2010 | 07:20 PM
jaychevyman's Avatar
Car: 90 camero rs
Engine: 305 5.0
Oil leak
Wazzup, I have a 90 camero rs 5.0 tbi. I have a oil leak coming in past the pcv valve into the air filter housing. I changed the pcv valve already but the pcv filter is still just soaked with engine oil. The air filter and housing has oil everywhere. What is the problem, any help appreciated
Old Oct 20, 2010 | 10:53 PM
mlynch001's Avatar
Car: 1985 El Camino SS, 2004 Trailblazer
Engine: Hybrid 305, 91 SD TPI, lots of mods
Transmission: 200-4R
Re: Oil leak
The PCV valve does not go into the air filter housing. PCV should be in the left valve cover and the air vent in the right cover The pipe from the valve cover to the Air filter is the air inlet that allows air to enter the engine and then be drawn through the engine by suction controlled by the the pcv valve, into the intake and burned in the engine. Either excessive blow-by or malfunctioning PCV system is your problem.
Old Oct 20, 2010 | 11:05 PM
Firebirda7x's Avatar
Car: 1986 Firebird Trans Am
Engine: Chevy 355
Transmission: Built 700R4
Axle/Gears: 9 bolt 2.77
Re: Oil leak
If I remember correctly if your PCV valve is stuck closed excessive crankcase pressure will build up and blow oil into the vent tube that connects to your valve cover and take some oil with it backwards up to your air filter.
Old Oct 30, 2010 | 05:35 AM
Car: 90 camero rs
Engine: 305 5.0
Re: Oil leak
maybe that is the problem. Ill look into it. Thanks for the help
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
