406 not making what it should.
Old Oct 22, 2010 | 01:23 PM
Crazy88's Avatar
Car: 1992 B4C 1LE, 1992 5spd TBI
Engine: 400, 305
Transmission: Tremec 3550 TKO, T5
Axle/Gears: 12 Bolt Moser 3.73, 10 Bolt GM 3.08
Ok i have a 406 with
stock crank
forged 6inch rods
forged icon pistons
195cc afr heads
comp cams 274XR full roller everything
1.5 rockers
holley strip dominator manifold
and 750 holley carb.
headers prolly to small but are 1 5/8 to 2.5 to Y into 3inch back
has th350 full manual valve body, with 2500 stall
what do you guys think it should be its rwhp and at the crank.
let me know what you guys think.
Old Jan 24, 2011 | 11:04 PM
Crazy88's Avatar
Engine: 400, 305
Re: 406 not making what it should.
anyone got any thoughts?
Old Jan 25, 2011 | 11:30 AM
jerrod75110's Avatar
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
You say its down on power...bad track times? or it dont feel stong?
Whats the compression ratio. Whats your timing set at?
Old Jan 25, 2011 | 12:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
elaborate on not making what it should?
Exhaust is small for one thing... needs a 3.5-4" single catback.
xr274r solid roller? 236/242 cam? Is that the one you have?
Old Jan 25, 2011 | 01:26 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Give us compression, intake manifold and cam specs.
Old Jan 29, 2011 | 12:04 PM
Crazy88's Avatar
Engine: 400, 305
sry guys i haven't been on in a while. compression is around 10.2, timing i believe is around 33. the dyno shop set the timing good i forgot to ask final. it is the solid roller cam. the one thing the shop said was maybe too small cam but i don't think so. she makes 318 rwhp and 326rwtq. i was thinkin it should be more around 360 or so maybe close to 400 but didnt happen.
Old Jan 29, 2011 | 04:50 PM
Car: 89 camaro
Engine: 383
I would have to say need bigger exhuast.1 3/4 headers and duals or BIG single. also that many cubic inches will mild down the cam. Could use a step or two bigger cam.
Old Jan 29, 2011 | 08:40 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Youd pick up a whole gang of torque with a good dual plane like a performer RPM.
Thats a good cam on a 406...even with a 1-5/8 header you should be close to 400rwq Id guess..
33 on timing....initial or total, doesnt sound right.
Think you need to go back to some tuning recheck the curve and when it comes in.
Old Jan 30, 2011 | 05:33 PM
Crazy88's Avatar
Engine: 400, 305
33 is total. and it peeks around 5700. we built it to go maybe 6300 or so. what could be stoping that? cam?
Old Jan 30, 2011 | 07:08 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Small exhaust.
Are you using good fuel? No det.?
Old Jan 30, 2011 | 07:28 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If you want to turn 6300 rpm peak, you will need alot more cam and could use more head.
mddaniel
Sep 8, 2015 05:16 PM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
trevor1010
Aug 24, 2015 11:29 AM
Regal105
Aug 23, 2015 03:45 PM
