Steering pump loose / March brackets
Old Oct 30, 2010 | 08:35 PM
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
HI,
I got a March pulley and bracket kit with an electric waterpump!
my problem is that my steering pump going loose everytime after a few miles cruizing.
i see wen i pull on the steeringwheel the whole pump moving up and down.
so my belt is going a little loose and the pump is no more in line with the crank pulley!
is there a special extra heavy bracket for the pump?
i think there must be a extra bracket on the backside of the pump.
did somebody heart about the problem?
thanks dennis
Old Oct 30, 2010 | 09:31 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Steering pump loose / March brackets
In your 2nd pic, what is the piece that looks like it's hanging down, just to the right of the balancer pulley & water pump that looks kinda like a backwards " j " ?
In the March pic, they have 2 black parts-- 1 behind the alt, & a " L " or
" ] " looking part behind the steering pump. Are those included? Not needed??
I've never seen it in person, only in Jegs & Summit, but just caught my eye.
Old Nov 1, 2010 | 11:42 AM
Car: camaro iroc-z
Hi t-top havoc,
in the second picture u see a `J` that is a kind of bracket.
in that picture it wasn`t installed yet !!
in the March pic were you talk about, are the spacers for the alternator and PS brackets! you must buy it appart. you need them only when you take a electric water pump.
Old Nov 1, 2010 | 01:15 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Ive had the same problem with march stuff, too.
Is it fine, but then comes loose, or does the whole bracket flex at all times even after tightening the bolts?
Old Nov 1, 2010 | 07:34 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yep - in that 2nd pic, the bottom of that backwards "J" that was pointed out attaches to the back of the P/S pump.
Old Nov 2, 2010 | 12:07 PM
Car: camaro iroc-z
how did you fix the problem?
Old Nov 2, 2010 | 01:29 PM
Car: '87 Camaro
Iroc-Dennis---
If you're taliking about the bolts needing to be re-tightened, give it a few days of driving & adjusting so the belts get stretched enough, then use some type of thread locker.
Old Nov 2, 2010 | 05:27 PM
Car: camaro iroc-z
no sorry it is not the bolts that must re-tightened. the bolts are just fine!
the problem sits in the steering pump brackets.
if you steering a few times you can see moving the pump from left to right a little!
i think i must make an extra bracket on the back side of the pump so hey can`t move anymore.
guys let me know how you fix it!!
dennis
Old Nov 2, 2010 | 05:30 PM
Twin_Turbo's Avatar
the problem is simply the design of that bracket. The best solution is to fabricate a strap that bolts to the back of the pump and to the block somewhere so it's in tension when the belt is pulling on the pulley. A good location would be that extra header bolt hole not used on your L98 heads.
Old Nov 3, 2010 | 05:09 PM
Car: camaro iroc-z
i have make a piece of metal (strip) from about 3 cm tall and 10 cm long and 0,5 cm thick. make some holes in it and connect is from the back of the pump to the front of the head were i can put a bolt in!
i must check end this week if it works,it was to late for today.
i let you know and make a picture!
dennis
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Genopsyde
Nov 11, 2015 10:46 PM
backtothe80s
Sep 5, 2015 12:39 AM
Dialed_In
Aug 20, 2015 01:45 PM
