Gutting the converter............
Old Oct 31, 2010 | 07:08 AM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
I know many of us have gutted the converter on our cars. What are some steps you need to take along with that to prevent running poorly? What types of symptoms do you normally see?
Old Oct 31, 2010 | 07:17 AM
MC305SS's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200R4
Re: Gutting the converter............
Nothing really.
Cars of this age do not use post cat 02 sensors so you get no codes.
And even then running no cat or gutting it affects anything as far as its running, just the air gets affected!
Old Oct 31, 2010 | 08:11 AM
jwande's Avatar
Engine: 305 TBI
What about back pressure?
Old Oct 31, 2010 | 08:27 AM
MC305SS's Avatar
Transmission: 200R4
Yes is lowers back pressure and thats why people do it, to add some performance by it being lowered.
Does not affect how the car runs in anything negative other than emissions output rises.
Old Oct 31, 2010 | 08:35 AM
jwande's Avatar
Engine: 305 TBI
Re: The TBI glitch that I can't fix
Quote:
Originally Posted by cal30_sniper
Will definitely check the timing this weekend. I wouldn't think it would be the fuel pressure, as the problem would only get worse as I went further down with the throttle, not better.
Unplug and block the EGR hose to the EGR valve. See if your problem goes away. If it does, install an EGR valve for a TBI 305/350 truck. The stock L03 car EGR valve relies on exhaust backpressure to keep it closed. Truck EGR setups require backpressure to OPEN. You have taken the backpressure away from your exhaust system which allows your stock EGR valve to flop right open. That is the difference between positive and negative backpressure EGR valves.
This statement was made on another thread. I always thought that engines needed a certain amount of back pressure to operate properly, but I didn't know how much. Given that this is the first time I have gutted a converter, I have no history to go by. I thought I might get the thoughts of my fellow 3rdGenners.
Old Oct 31, 2010 | 08:44 AM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
Just gutting a cat doesn't affect the back pressure as much as your thinking, having a bunch of big pipes straight out the heads is bad because of not enough pressure, but having a full exhaust out the back with headers and a gutted cat is perfectly fine
Old Oct 31, 2010 | 09:27 AM
jwande's Avatar
Engine: 305 TBI
I was hoping that is okay since I already did it! Just trying to chase down an idle stumble and poor high rpm performance.
Jeremys87
Jul 14, 2022 09:08 PM
L98FORM89
Aftermarket Product Review
Jun 27, 2001 07:27 PM
Dellz
Oct 30, 2000 05:39 PM
