305 heads
Old Nov 1, 2010 | 04:01 PM
smoothjazz's Avatar
305 heads
Quick question concerning a set of 1984 305 heads.Will this year head bolt on will no problem onto a 87 and higher 305 block.
Old Nov 1, 2010 | 05:23 PM
Re: 305 heads
Block, yes.
The 87-up intake however will NOT bolt to those heads without some work. Very minor, but "work" (now I gotta go was my mouth out with soap for using 4-letter words, like my mama always used to make me do) just the same.
You'll need to elongate the center 2 bolt holes on each side, in the inward direction, so that the bolts can go in at the same angle that the other 4 on each side do; and you may need "angle washers" to go under them, which you can get from McMaster-Carr among other places. www.mcmaster.com
And of course you'll have to use 86-back valve covers, with the bolts around the perimeter; and 86-back rockers, WITHOUT the little "rails" that center them on the valve stems. All very minor trivial eeeeeeeezy stuff.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
