Random SES Light + popping sounds Help?
Old Nov 12, 2010 | 02:12 AM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
91 Camaro RS 305 TBI
Recently when i start the car it idles at about 1500 RPM (warm) and u can hear faint popping sounds coming from the exhaust.
I had my car fixed earlier this month with a new fuel pump and the timing was adjusted, does this have anything to do with the timing?
The car drives fine and all... doesn't stall or anything anymore but i don't think its normal to have the popping sounds..Sometimes the SES light comes on in the first 5 mins of driving then goes away.
I checked the computer for codes and it gave me a code 22.
Which points towards the TPS adjustment (TPS is new) or Bad ECM
Can anyone give me a noob explanation on how to adjust the TPS? I bought a multimeter a few weeks ago and started poking around there and just had random readings..What should my multimeter be set to read? and what exactly should i check?
Im pretty sure the TPS is unadjusted because when i was troubleshooting my car a while back i did turn the little tps **** a bit so i might have messed something up, im not sure.
Thanks for reading, any help appreciated.
eightsixseven
Dec 16, 2024 01:50 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
fonzie85
Aug 13, 2015 11:50 AM
Omega
Aug 10, 2015 12:46 PM
