350 idle problems
Old Nov 15, 2010 | 08:23 PM
crystal383's Avatar
350 idle problems
i'm trying to get my small block to start up. the engine has already been tuned on an engine dyno and everything was working perfect.
i took it home and it set on an engine stand for a couple months while i was getting my camaro ready to drop it in. finally dropped it in and everything. started it up the first time and it ran good. then the next day i started it up and it barely held idle. the day after it wouldn't even hold idle and would just back fire.
i finally found that the distributor clamp bolt was loose and the distributor was getting more and more out of tune. so i started over by putting the number one piston 15 degrees before tdc. it fired up nicely but then started to climb in rpm's. so i tried advancing it a little and then it wouldn't start at all.
so today i set it back to 15* and now it won't even start at all.
Old Nov 17, 2010 | 01:27 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 350 idle problems
is the vehicle carbed, tbi, or tpi?
Old Nov 21, 2010 | 03:25 PM
crystal383's Avatar
its carb'd. its got 9.4:1 compression. the cam's duration @ .50 int 244*/ exht 252* on a 110 lsa.
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
gta power
Aug 13, 2015 06:15 AM
