engine hard to turn after rebuild
Old Nov 21, 2010 | 03:13 PM
Mike-92-RS's Avatar
Car: 07 Tundra, 92 RS camaro
Axle/Gears: 3.42 posi
I am rebuilding a LS1 to go in my 92 camaro and it takes 200 foot lbs of torque to get the engine to turn. Once the engine starts to turn then it is easy to turn. Is this normal for a complete rebuild or do I need to take it back apart?
Old Nov 21, 2010 | 09:46 PM
Vader's Avatar
Re: engine hard to turn after rebuild
I've had SBCs require 70-80 ft/lb to turn (with no plugs in, of course) but never than much, even with 300# valve springs. What cam/springs are installed? What was the ring end gap? Skirt clearance? Did the assembly lube wash out somehow? I'm assuming the engine is in a stand, and not mated to a transmission, correct?
Did you test the crank in the mains before installing the rods/pistons? That usually requires only a few inch pounds to break free.
Old Nov 22, 2010 | 06:39 PM
mlynch001's Avatar
Car: 1985 El Camino SS, 2004 Trailblazer
Engine: Hybrid 305, 91 SD TPI, lots of mods
Transmission: 200-4R
No, that is not good! 200 Foot Pounds to start it turning? How did the crank turn before you put the rods and pistons in the block? I would say a problem with one or more rods, maybe a mixed up cap or a piston installed backwards? Did you bore the cylinders? could be wrong end gaps on the rings.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
