350 vortec??
Car: 1990 iroc
Engine: 5.7 vortec
Axle/Gears: 4.11
350 vortec??
hey wats up everyone ... i got 1990 iroc . i just threw in a 350 vortec out of a 99 tahoe, runs great but i wanna put a different cam ,nothing too crazy i just want a good solid daily any suggestions or anything else i should do ??thx in advance
Transmission: 4L80E/4L80E
Re: 350 vortec??
Welcome aboard thirdgen.org.
Stock Vortec valve springs can't take much more than stock Vortec lift & RPMs. Aftermarket valve springs are a must.
If you go with beehive springs, you can also gain more valve travel. Otherwise, don't exceed .480" lift without pulling the heads and having the top of the valve guides cut down (actual lift # reports vary - some say they've seen unmodified Vortec heads that couldn't handle .440" lift).
Car: 1990 iroc
Engine: 5.7 vortec
Axle/Gears: 4.11
Re: 350 vortec??
so basically i need to start with the heads ,im kinda new to dealin wit motors i kno how to put em in just dont kno muck enternally about motors , so what all do i do with the heads ?? i thought vortec heads where good
Car: 1994 Z28
Engine: 355 LT1
Re: 350 vortec??
Vortec heads are good and with a little bit of machining they are impressive to say the least. From what I have been told, it's best to not run anything bigger then a .430" lift cam on stock heads. If you pull the heads and send them to a shop they will set them up (relatively cheap) to accept a much larger cam; such as the LT4 Hot Cam .525" lift. On this setup you can see 400 horses pretty easily.
Car: 1990 iroc
Engine: 5.7 vortec
Axle/Gears: 4.11
Re: 350 vortec??
thanks for the info but if i send them to a machine shop wat do i need to do exactly thanks in advance
Car: 1994 Z28
Engine: 355 LT1
Re: 350 vortec??
Read this, it will answer everything you need to know:
http://www.chevyhiperformance.com/ho...458/index.html
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Re: 350 vortec??
Also read this, goes into a lot more detail. One other thing, try to type and spell correctly, it makes people take you seriously and want to help you instead of getting pissed off trying to read lazy type like kno and wat. You will get more quality help by speaking like a grown up.
http://www.nastyz28.com/forum/showthread.php?t=56505
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1994 Z28
Engine: 355 LT1
Re: 350 vortec??
You plan on keeping the motor fuel injected? If you switch to carb, it will fit just like any other small block. If you keep it fuel injected you might have to take off that airbox they have, I don't know.
Car: 1990 iroc
Engine: 5.7 vortec
Axle/Gears: 4.11
Re: 350 vortec??
ya i went carbeurated.. it went in just fine with all front accessories ac comp kinda sit up high tho
Car: 85 Z28
Engine: 327
Re: 350 vortec??
Yeah I would probaly keep FI. I was curious about accesories because I hear with an LS swap , if you use motor form truck you have to get car accessories. I would probaly delete AC so it sounds like it would work good.
Car: 1990 iroc
Engine: 5.7 vortec
Axle/Gears: 4.11
Re: 350 vortec??
no truck accessories works in mine even with the ac .. ima rookie at all this so i kept the carb,wish you luck with that . send pics when finish
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 350 vortec??
You can use everything that comes off the front of a 3rd gen V8 on a 96-98 Vortec 350.
86CamaroDan
Sep 29, 2015 10:08 PM
