small backfire from engine
Old Dec 2, 2010 | 02:18 PM
84'transam's Avatar
Car: 1984 Trans am H.O.
Engine: 305.
Transmission: t5
hi i had installed some headers on my 84 ta and i han ran it to see how it sounded. it didnt sound like i thought it should so i took off my valve covers and i had notices that the 8th cylinder exhaust rocker was off and that the pushrod was stuck. after i fixed that i had gone to get an exhaust system and noticed that there was a small pop coming from the engine. when i went to the back of the car the exhaust sounded uneven. my question is even though i replaced the lifter and pushrod could the cam lobe be messed up because it still backfires. much appericiated for the feed back.
Old Dec 3, 2010 | 08:14 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: small backfire from engine
Possibly, but could also be a bent valve. Were you able to determine why it happened in the first place?
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
