Oil specifications
Oil specifications
hello,
i want to know what kind of oil can i put in my camaro z28 1982 (4bbl)
on camaro 's french forum , they said 15w40 or 20w50 mineral oil .
my engine is full stock and the temperature where i live are between -10 ° ,-15° C on winter and 20-30 °C on summer .
what about APĪ specs ?sc/ch is good ?
thanks for answer ...
Re: Oil specifications
That is MUCH too thick.
Ordinary regular motor oil is fine. 10W-30 is about perfect. Doesn't have to be "mineral" oil; you can use synthetic oil if you want (I recommend it).
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Just go to wal mart and get some 10w-30 castrol or valvoline and you'll be fine.
i live in north of france ...no wal mart .
in france , cars shop call 'norauto', 'feux vert', 'midas' but they are stupid and don't know anything in mechanical....they are more stupid than an ape .
i do all maintenance myself ...
what you think about this:
http://www.norauto.fr/Acheter-Huile-...autoSI-/5.html
api spec is sl/cf ....good for me ?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It will be a little thicker in cold weather, but it will work.
This is the best I can see on there http://www.norauto.fr/Acheter-Huile-...autoSI-/1.html
its a little thick but should work. Trending Topics
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I would recommend oil with higher levels if zddp cause it is a non roller engine. Use something with 1200 ppm of zddp. It has been suggested to me to run Rotella Diesel oil. I use SM rated oil with an additive in my 86 engine.
skinny z
Oct 5, 2015 06:23 PM
