What does the ecu do?
Old Dec 11, 2010 | 08:00 PM
nfeuerhelm's Avatar
Alright so I'm getting close to doing some engine and electrical work on my 82 camaro. Before I owned the car a couple mice had gotten into and messed up some of the accessory wires. I've also found that all the fuseable links put on these cars are always in the worst places and are almost impossible to replace without adding a small fuse block. So my plan is to replace my whole wiring harness, I like electronics stuff and I don't think it'll be a huge headache. But since I also want to upgrade my 305 4bbl, I wan't to know what the ecu does for a carbed engine. From what I know about engines it doesn't seem like it should really be necessary? What does it actually control? Any help would be great, thanks.
Old Dec 11, 2010 | 09:44 PM
talover111's Avatar
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
Re: What does the ecu do?
two main things would be the carb and distrubutor
Old Dec 13, 2010 | 08:00 PM
nfeuerhelm's Avatar
So does the h.e.i. distributor need the ecu to work properly? Cuz I thought it was mechanically controlled. And I plan on putting on an edelbrock performer carb. So it seems like I could go ahead and get rid of it.
Old Dec 13, 2010 | 09:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends on the distributor. The older large cap distributors were normally a self contained unit only needing a good power supply while later models had computer controlled modules in them. The newer small cap systems are computer controlled.
I've worked on late model trucks with Vortec engines that were converted over to propane fuel. The ECM was still kept to control the electronic transmission but the computer had no control over the fuel entering the engine. The injector harnesses were simply taped up and left on the intake. All the other sensors were kept in place and the computer still controlled the ignition.
In order for the transmission to shift properly, the TPS still had to be used so that the ECM knew how much throttle was being applied. If converting to a carb, there's ways to adapt a TPS onto a carb if you have an electronic transmission.
Old Dec 13, 2010 | 09:10 PM
nfeuerhelm's Avatar
Well I'm almost completely sure that the transmission in mine is a standard TH350 with a standard valve body, I just don't know if its a forward or reverse pattern. Though I would have to look at my distributor a bit better to check on it. There seems to be a couple wires on it going to the ecu on the wiring diagram I have. I just kind of need to see how that goes. I'm not around my car right now so that'll probably take me a little while.
Old Dec 17, 2010 | 06:43 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Unless it's an implant, the 82 doesnt have a TH350. It would have a TH200 (may be a TH250, cant remeber for sure). The large, internal coil HEI distributors went to EST, or computer controlled timing starting in the late 70s on some GM cars. Cadillac was the first to use this system. The F-bodies went to EST in 82 on both carb and FI applications. You can identify the EST dist by the additional four pin connector coming from the base of the unit. The self contained(mech advance) HEI didn't have this.
To eliminate the ECU in a CCC carbureted application, you need to install a non feedback carburetor and a mech advance HEI dist. Your fan on the 82 should be mechanical as well as your fuel pump.
Old Dec 17, 2010 | 07:26 PM
nfeuerhelm's Avatar
What constitutes a non-feedback carb? and yes right now I do have the mechanical fuel pump and mechanical fan. I do plan on switching to both electric, but on their own controls. I guess I was remembering wrong on my transmission, I'll have to look at that and my distributer when I get home for winter break.
Old Dec 21, 2010 | 06:56 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
I would definitely stick with the mech fuel pump for carb application. Electrics are alot more trouble. By non-feedback, I mean a standard carb with no computer controls. If your 82 is still OE, it has a feedback carb. You can tell by the 2 electrical connectors at the front of the carb. One is a 3 pin and is the TPS. The other is 2 pin and is the mixture control solenoid. This carb will not function properly without the ECM. You will need to replace it with either an earlier Q-jet or an aftermarket unit(Holley, Edelbrock)
gixxer92
Apr 12, 2022 12:09 AM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KO1
16
Oct 15, 2015 05:00 PM
tuningnewb
Sep 23, 2015 07:06 PM
