build a new one? or buy a new one?
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
I have a question. I would like the opinions of you guys about something.
It is coming to the time when I need a new engine. Now I'll only have about $2,500 to spend. I have been beating myself up for months now about if I should buy a stock l31 and do some up grades later(that would be about 5 years later when wifes car is paid off) or take the money and build an engine with performance upgrades. I have the ability and knowledge to build my own I just don't know what the better choice would be?
I want the l31 for the vortec heads, so If I want to later down the road I can upgrade the cam and intake and have a nice street car.
But I also have priced a Hot Cam, HSR, rotating assembly, and patriot vortec heads and it would be right around the same price as the new l31 but I would have the performance up grades now.
I guess I would just like to hear your opinion on what you would do with this choice at hand? So any opinions good or bad is welcome, I just need advice in making my decision so I don't pull all of my hair out thinking about this
Transmission: 4L80E/4L80E
Engine rebuild kit with pistons, rings, bearings, gaskets, seals, oil pump from Summit - $450
Timing set - $50
Upgraded Vortec head kit from SDParts.com with TPI intake - $1765
Machine work (block, crank) - $350
That's slightly over your $2500 budget. If the block only needs rings, not pistons, then you can cut that down considerably. And maybe add a Hot Cam to the list ($205).
Timing set - $50
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: build a new one? or buy a new one?
for my two cents worth, I say rebuild. You'll have the satisfaction of accomplishment once you're done.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You dont have to use vortec heads. There are other heads that flow just as well as teh vortecs and have a standard port so you can use your stock intake with a few mods, such as porting and better runners. Might save some money over buying a new intake and heads.
Engine: 350 for now
Transmission: wc t5
Timing set - $50
Timing set - $50
The engine block has had the machine work done. and the crank was turned 10/10 BUT!!!! a faulty tailgate and 75mph destroyed the crank and pistions that were in a box in the back of my truck driving back from the shop. the effin tailgate fell down and the pistons, rods and crank were in a box and hit the highway at 75. the few pieces i did find are no longer useable.
I was thinking on getting a whole rotating assembly from summit and patriot vortec style heads with a hsr and a new timing set from jegs and then finding a hot cam to go along with that. and a gasket set.
I'm just trying to weigh the options of the rebuild vs the cost of the new long block. and I will only get to do this once for the next 5 yrs so I have to make the right decision.
But I do thank you guys for taking the time to share your opinions and I will take all into consideration
