Is it safe to unbolt ac lines?
Old Dec 16, 2010 | 12:55 PM
SSZ2891's Avatar
Ok so im beginning to remove my 305 from my 92 rs. Its got a blown head gasket. Ive got a lot accomplished today. I just got to the ac lines. Is it safe to unbolt them or will the pressure be too high that it could be dangerous or harmful to me at all? Thanks
Old Dec 16, 2010 | 01:01 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Is it safe to unbolt ac lines?
Best if you evacuate the system first.System is under a bit of pressure.You could open the low pressure valve & let it out that way, but thats illegal.
Old Dec 16, 2010 | 01:06 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
You should be able to move the pump to the side of the engine bay so its out of the way. Use some zip ties to keep it in place. This way you wont need to disconnect the lines and should give you enough room to work.
Old Dec 16, 2010 | 01:17 PM
SSZ2891's Avatar
what would i have to do if i wanted to remove the whole ac system from the car? and where would the low pressure valve be.
Old Dec 16, 2010 | 01:19 PM
SSZ2891's Avatar
also what should i do about the power steering lines and the pump itself. remove it or leave it connected.
Old Dec 16, 2010 | 01:26 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Low pressure side is the valve on the aluminum cylinder by the AC/heater box.
Remove the P.S lines from the box, leave the pump inplace.
Old Dec 16, 2010 | 01:42 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
I took the entire a/c system out of my car while it was still pressurized. You need to have the radiator out and once everything else is unbolted you can lift it all out.
I was planning on putting it back in until I knocked something over in the garage that fell on it and pierced the condenser and she started hissing..
J-money
Jan 4, 2019 09:45 AM
86IROC112
Nov 27, 2015 09:54 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
89 formula TPI
Sep 8, 2015 08:00 PM
UMI Performance
Sponsored Vendors
Sep 4, 2015 09:22 AM
