daily driver, would it be worth it?
Old Dec 17, 2010 | 10:41 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Transmission: 700r4 stock
the motor I have now is a stock lo3 so anything is a upgrade.
I need an honest opinion. I want to build a 350 (Budget) a man gave me a set of (good) camel humps off of a corvette for it (with bracket holes) what do you guys think. this is the bottom end this is all I know about it I bought the block made like this:
Fresh 40 over 350 block 2 bolt main with arp main studs
Bored and honed with torque plate, decked
Brass freeze plugs with clevite cam bearings
Cast crank turned 10/10 with clevite main bearings
Rebuilt rods with arp wavelock bolts and clevite bearings
Speed Pro Hyperutectic flat top pistons with speed pro moly rings
Assembled with all clearances checked
not a super fast race car just a fun DD anything near/close to 300hp is fine
talk to me!!!!!
Old Dec 17, 2010 | 11:15 AM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: daily driver, would it be worth it?
Vortec heads will give you a lot lower compression, better driveability, and flow a lot better than any other gm oem head. They come off of the '96-02 tahoe and trucks.
Old Dec 17, 2010 | 01:10 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
You can get 300 horse on that set up but you'll be pushing streetabilty on a stock stall. I'd imagine you need a pretty high lift cam if those heads aren't machined.
Old Dec 20, 2010 | 03:05 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
hey, quick "?" IF I get a fresh set of Vortecs to go in conjunction with this bottom end I guess what I'm asking is what I can expect as far as (CR) and octane, streetability,horsepower, Daily driver?, detonation probs, Quench, remember the block is decked. it will have a carb. and of course the block still needs: intake, carb, oil pump, headers, oil pan, dist., cam, double roller timing chain, lifters, and rods
Old Dec 20, 2010 | 03:49 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
rumor goes.... vortec heads.. lt4 hot cam and 1.6 rr equals to about 400hp....
Old Dec 20, 2010 | 03:50 PM
spade's Avatar
on a stock bottom end
Old Dec 20, 2010 | 04:17 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
"Driveability issues?" or should I say on premium gas or rocket fuel?
Old Dec 20, 2010 | 04:40 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
No? with that combo it should be 89 probably, and that would be fine.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
my86bird
Oct 23, 2015 12:20 PM
rsrookie
Sep 5, 2015 07:08 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
