Fuel pump or relay?
Old Dec 17, 2010 | 06:19 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Fuel pump or relay?
Hi, How do i tell if i have a dead fuel pump or relay? No pump noise at key on... ( verified by fuel press guage ) Car was idling in garage .. i was collecting a data log to try out a new bin i'm working on, Pump is original 1992 vintage and has aprox 60 on the clock. The data i collected during the no start condition shows NO voltage at the fuel pump ( via TP/RT ) but yet voltage appears during cranking then goes to zero when cranking stops
I even tried the prime wire near the relays ( advice from GM mechanic friend )
supposed to go direct to pump but with 12 volts applied still silence, any thoughts? I really want to make sure it is the pump and not something else, thanks GTA....
Old Dec 17, 2010 | 06:37 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: Fuel pump or relay?
Which wire did you apply voltage to?(color,size)
I just had to replace the fuel pump on my fathers '94 chevy pickup with 54k on the odo. Age is everything.
Old Dec 17, 2010 | 06:50 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
I applied 12 v to the red wire ( flat spade connector ) this wire is sticking out of the wireing harness near the relays on the driverside firewall. I was told to do this by my mechanic to verifiy a dead pump....
Old Dec 17, 2010 | 06:58 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
That's interesting. Never heard of a wire with a spade connector on it sticking out of your harness to be a good thing.
However your fuel pump relay should have a gray wire coming out of it, this is the one you want to apply 12volts to.
Old Dec 17, 2010 | 07:07 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
sorry i should be more specific... the wire yes its red, that was the color he told me to look for the connector is a female end that requires the flat spade connector. Which relay controls the pump, left or right? maybe i can swap them around to verifiy correct operation?
Old Dec 17, 2010 | 07:11 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
I'm not sure whether its the left or right because I have an '89....But it should be the only relay there with a solid gray wire, this runs through the fuel pump fuse and supplys power to the pump. Wouldn't be a bad idea to check that fuse as well in case you haven't.
Old Dec 17, 2010 | 10:26 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
89 thanks for the reply...
I checked the fuse box and i do not see any fuse that is dedicated or together with something else for the fuel pump, i am going back to check in the am again would a blown relay show the symptoms that i am describing?
Everthing shows normal except no fuel pump, BTW how the heck do i post a TP xdl file on here to show you what i mean? thanks GTA.....
Old Dec 17, 2010 | 10:40 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
I have no idea about posting tuning files. But I know how to hotwire a fuel pump .
Oh, assuming its like any other document file try saving it as a .jpeg and posting as a picture.
Old Dec 17, 2010 | 10:52 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
hmm, just noticed something when reviewing my data log of the no start condition....Key on there is NO voltage at the pump ( via TP/RT ) during cranking the voltage goes up to normal BUT the Inj PW remains at zero?? when cranking stops pump voltage falls to zero....what the heck is going on?
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
Kaweh
Aug 9, 2015 02:54 PM
