best way to spend 3,500
Old Dec 18, 2010 | 01:11 AM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
Transmission: t5 non worldclass
i have a 67 327 i am planning on trying to acheive 400hp at a low rpm and need advice on a good set up , i want to be scared to drive my car. well i already know what you are going to say "ditchthe 327 and build a 383" i have been sereiously thinking about it. i have access to a four bolt 350 for three hundred dollars. and well i have been doing research online but everyone contradictes each other all the time and it is getting harder to sift through all the bull***t!? and well makealong story short my jag got crush and i am trying to get compinsation. $3500 is lowest i get so that is what i am planning for. everything works but no motor... 2.73rear std diff 5sp manual. actually my 305 was leaking coolant into my cyilander, so its smoked, only put out 140 hp brand new so it super lame it was out of a 75 malibu, anyways tell me what you think....
Old Dec 18, 2010 | 01:30 AM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Re: best way to spend 3,500
Build the 350...
Old Dec 18, 2010 | 01:33 AM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
Originally Posted by david068513
Build the 350...
yeah i think your right
Old Dec 18, 2010 | 01:35 AM
Axle/Gears: G92
Build it with nice internals, nice heads, intake, cam, and have a fun street car.
Old Dec 18, 2010 | 01:38 AM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
yeahi have all three of the shoe string stroker articles
that super chevy did in 2007
Old Dec 18, 2010 | 01:39 AM
Axle/Gears: G92
Idk which one your talking about. I don't read that mag that much. Is it gonna be efi or a carb motor?
Old Dec 18, 2010 | 04:10 AM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
i have already bought a edelbrock performer rpm intake and a performer 650 carb well that would be another grand to build a 383 instead of the 327 i already have so i guess my question is if i buy a set of rhs 200cc pro action heads 1.6 roller rockers can i get a comp cam that will put me in the 400hp range??
Old Dec 18, 2010 | 06:19 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I've got a 385 I guess, it's 40 over instead of 30 in my 88. Wish I'd went with 350. This engine is fun but PITA to keep cool with AC. But in your state that may not be a problem. JMO
Old Dec 18, 2010 | 08:30 AM
MC305SS's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200R4
With a $3500 budget, no wanting to keep the current motor, maybe wanting a nice warranty, proven results etc, CRATE ENGINE!!
Old Dec 18, 2010 | 04:12 PM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
??????????can i do it?
Old Dec 19, 2010 | 05:59 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I say 5.3 or 6.0 swap.... your a cam and exhaust away from 400hp.
Old Dec 19, 2010 | 06:27 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yeah a carb 6.0 would do it for sure but then what? trans and rear??? I think way too many people cut corners on the rest.. But you will be scared to drive it for sure because you know the rear will pop
Old Dec 19, 2010 | 06:32 PM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
327 is a 5.3 l why would i need to swap for a newer one that says 5.3l when i have an old one that equels the same displacement? they both should put out around he same amount of power and on the old one i can put a badass setup on it for cheap my question is will it make 400?
Old Dec 19, 2010 | 06:36 PM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
lol ha i sure would but i am installing an 8.5 in her with posi lsd and 4.10 gear and disc brakes. only thing left to replace is the t5 with a t56 then i will be done for awhile.
F-body-fan
Jan 12, 2023 01:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
