89 formula
Old Dec 21, 2010 | 08:07 PM
biglano's Avatar
Car: 89 formula
Transmission: 5 speed
89 formula
i bought this car in the atlanta area, drove it to charlotte, nc. everything ran fine for about 2 weeks. the car has 350, 5 speed, TPI. whilepulling out of a parking lot one day, when i shifted to 2nd gear, it died. like it was out of fuel. i ended up towing it home, it wouild crank over but not start. to fire, nothing. a few days later, it started, i drove it a few miles, died again. seemed like it was not getting fuel. i changed the fuel filter first, it happened again. towed it home again. since then, i have changd the fuel pump, the coil, the didtributor, new wires, new cap, new rotor. in the past, i had a 1988 trans am that acted similarly, it turned out to be the on board computer. i replaced that as well in this car. it still does the same thing.
Old Dec 22, 2010 | 07:17 PM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Re: 89 formula
I would ohm test your injectors. The injectors seem to cause a lot of head-aches with these engines...
Old Dec 23, 2010 | 01:29 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 89 formula
There's a Charlotte F-Body club - pretty big - lot of great F-Body gearheads there - have you gotten up with them? I'm sure there's a local that can help you in person (always hard to diagnose sight unseen). Just type Charlotte F-Body in Yahoo/Google and you'll find them.
Old Jan 1, 2011 | 09:13 PM
biglano's Avatar
Car: 89 formula
Re: 89 formula
how much trouble is it to take the TPI off and carburate it?
biglano's Avatar
Car: 89 formula
Re: 89 formula
the charlotte f-body group has almost no activity on their site.
Old Jan 1, 2011 | 09:25 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Re: 89 formula
My car acted that way when It heated up. It was a combination of bad injectors which in your case I don't think would cause it to actually kill. And it was the ignition module. You say you replaced the dist. I assume it came with a new one on it?
Old Jan 1, 2011 | 10:41 PM
biglano's Avatar
Car: 89 formula
Re: 89 formula
yes, it was new also.
i have a 650 cfm edlebrock carb sitting on a shelf. i read a tech article on here, looks like a fairly easy swap to put it on. i'm leaning that way pretty heavy.
I've had 3 other of these cars, 86, 88, and a 91, this 89 is the most fun to drive of all of them. 350 5 speed, w wheel disc brakes. it's pretty rough right nown needs a lot of tlc.
Linson
Oct 24, 2025 02:00 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
