Need help finding where dipstick goes into block
Old Dec 22, 2010 | 07:15 PM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
ok, well yesterday we bought an 85 Z28 with the TPI 305, and since it was the special ****** edition, one of the previous owners thought it would be funny to remove the dipstick tube. I tried comparing my Irocs engine to the Z28, but still cant find the place where the tube is inserted into the block, I know its on the passenger side, but other than that im not sure. If anyone could post a pic I would appreciate it, thanks in advance guys
Old Dec 22, 2010 | 07:33 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Re: Need help finding where dipstick goes into block
use a flashlight in the dark and look for the hole. Should be slightly above the oil pan on the pass side. You should be able to find it, unless it ran off
Old Dec 22, 2010 | 07:47 PM
dude we jacked it up , and still couldn't see anything(yes we checked with a flashlight), Im sure the person responsible for this plugged it up, because we drove it 70 miles to get it to our house, I just need a picture to confirm where the tube plugs in
Old Dec 22, 2010 | 10:11 PM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
I'ts on the passenger side of the block,just behind the front of the starter motor.My dipstick runs just to the rear of the #6 plug.It can be hard to see,The hole could be covered with dirt maybe.I dont know why anyone would plug it up.
Old Dec 22, 2010 | 11:00 PM
iluvmy91camaro's Avatar
Car: 1991 Chevy Camaro RS w/t-tops
Engine: BBC 396 .090 over (414)
Transmission: LS1 T-56
Axle/Gears: Shortened Ford 9, 3.25, discs, posi
I can guarantee that they woldnt plug the hole. Keep looking. You'll find it eventually
Old Dec 22, 2010 | 11:20 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Unless it's a replacement engine. Dipstick might have been in the oil pan only. Or look on driver's side just below the cylinder head, could be an earlier engine.
Old Dec 23, 2010 | 11:00 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
sreZ28
Aug 14, 2015 07:48 PM
matthew911
Aug 12, 2015 09:38 AM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
