Comp Cams XR264HR
Old Jun 1, 2009 | 08:35 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Comp Cams XR264HR
I have a 92 Z28 with the 5.7 TPI. The motor needs rebuilt, so I thought I'd put a little performance upgrade in it. Has anyone out there ever used the Comp Cams XR264HR cam, part no. 08-501-8? If so, any issues using the stock computer, stall, etc?
Old Jun 1, 2009 | 08:44 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Re: Comp Cams XR264HR
thats a nice cam, your stock heads will not support the lift even with stock rocker arms. youll need to have your car tuned or burn your own prom since since its speed density. Your stock stall will work fine.
Old Jun 1, 2009 | 09:31 PM
jtsk's Avatar
would you recommend dropping down a level in cam? I am new to computer controlled motors, and want to make sure I don't get in over my head on expenses.
Old Jun 1, 2009 | 09:54 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
to be honest I dont know alot about the speed density other than they are alot more sensitive to change than maf. From what I understand any decent cam worth the time and money for a swap is going to need a program. If anything I would go to a 269hr 12. The car will still be drivable just not as enjoyable as it can be with a tune.
Old Dec 20, 2010 | 05:10 PM
CalvinMD's Avatar
I thought as long as you stayed under.500 lift and replaced the springs with the proper ones in the cam kit all would be fine in a L98 5.7 TPI?? Explain "heads wont handle the lift"??
Old Dec 20, 2010 | 09:02 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Comes down to checking out at what lift your heads are maxed out( cfm flow ) ; any more valve lift is not going to gain anything
Your alum Vette heads are different to the cast iron F-Body ones being discussed above
Old Dec 20, 2010 | 11:03 PM
CalvinMD's Avatar
Thanks!...I'm just looking to make a strong street engine that has good driveability and sounds strong when I get on it hard
Old Dec 21, 2010 | 01:19 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I run a 388 with fast burn alum heads, comp XE262 cam, 10:1 compression, 52mm T-body in front of a modified stock plenum & runners on top of a Scroggin's Dickey High Flow TPI intake, and out SLP 1-3/4" headers.
Idles and sounds pretty much stock until throttle opens up, even with the stock exhaust. Tune was modified only for 30lb injectors, timing, and idle.
Old Dec 21, 2010 | 06:15 PM
jtsk's Avatar
as an update to this thread, I went ahead with the xr264hr cam in my car. I also installed roller rockers, had the heads and intake ported and installed headers. Still have to get a tune on it, but managed to get it all buttoned up before winter hit. Will try and finish the project up in the spring with a tune to fit the motor. Seems plenty strong even without a tune on it.
Old Dec 23, 2010 | 12:43 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
did you check the max lift with the new springs and retainers? stock is .460-.480
Old Dec 23, 2010 | 01:10 PM
jtsk's Avatar
I had the machine shop set the heads up at .488 intake and .495 exhaust respectively.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
Strick1
Sep 4, 2015 07:11 AM
