Diagnostics?
Car: 1987 Z28 Camaro
Engine: 30Slow
Diagnostics?
hey guys, i have an 87 camaro 305ci and the diagnostics tool to read for codes i have didnt read nothing? im wondering if i have the one that reads for 96+? if it is where can i get one that will read for older vehicles? im in canada so i haven't a clue. thanks alot for your help guys!
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Diagnostics?
is the tool diagnostic tool you have for OBD I or OBD II?
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Re: Diagnostics?
It is very easy to tell the difference. Can you post a picture of the plug for the diagnostic tool you have? I can tell you if you are unsure.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Diagnostics?
If all you want to do is pull the codes, do it for free with a paperclip.
https://www.thirdgen.org/forums/tech...s-dumbies.html
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Diagnostics?
'96 is OBDII (introduced in '96)
OBDI & OBDII connectors are not the same, if it fits your '87 it won't fit '96+.
At the least the scanner should give a code 12 with the key on and engine off.
Engine: 30Slow
Re: Diagnostics?
87ColdAirIroc-Z
Nov 9, 2001 04:31 PM
