1988 GTA Diagnostics won't blink the check engine light when I cross it over
Old Oct 6, 2017 | 04:42 AM
Josh Edler's Avatar
My service engine light is on and it floods kind of bad cross the two wires on the diagnostic port and when I turn the key on it won't give me any codes it just stays lit up can anyone tell me why it won't read off the codes and stays lit up the whole time any help would be appreciated
Old Oct 6, 2017 | 07:11 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: 1988 GTA Diagnostics won't blink the check engine light when I cross it over
Are you jumping pins A and B, two upper right terminals?
Old Oct 6, 2017 | 07:41 AM
Josh Edler's Avatar
yes the a and b but it won't do nothing the service engine light wont blink or nothing it just stays lit
Old Oct 6, 2017 | 07:47 AM
What has been done to this car?
Disconnecting the ECM but leaving the light driver module will make it do exactly that. For example a carb conversion.
Old Oct 6, 2017 | 07:53 AM
Josh Edler's Avatar
I have put new injectors new fuel pump new idle control valve a whole new tuned up new oxygen sensor new mass air flow and and everything I've done has not seen the help keep it from flooding and sometimes when you're driving it at about 2500 RPMs and push the clutch in to come to a stop it will die but it starts right back up and don't know why it does that
Old Oct 6, 2017 | 08:00 AM
TBRays98's Avatar
Car: 1989 Formula
Axle/Gears: 3.45 1LE Disc LSD
If youre doing the diagnostic check correct try unplugging the ecu and then plugging it back in. If it still doesn't work I would bet your ecu is bad.
Old Oct 6, 2017 | 08:03 AM
Josh Edler's Avatar
I have a computer out of a 89 model GTA TPI engine will it work in it and I've got one from a 87 GTA TPI my 88 had the 9th injector and I deleted it but my 89 didn't
Old Oct 6, 2017 | 08:57 AM
Josh Edler's Avatar
​​​​​ what is the light driver module
Old Oct 6, 2017 | 09:07 AM
Josh Edler's Avatar
what is the light driver module and where is it located
Old Oct 6, 2017 | 11:16 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Sounds like you have a bad 1227165 ecm . You can tap on the case while the engine is running to see if the engine acts up.
https://www.thirdgen.org/forums/tech...ough-idle.html
Old Oct 6, 2017 | 11:29 AM
Josh Edler's Avatar
When I change the computer do I need to put my old chip in it
Old Oct 6, 2017 | 11:31 AM
Engine: Lb9
Transmission: M20
Yes
