273-373 Gears
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
273-373 Gears
I have a 91 firebird it has a rear end from a 89 forumla it has 273 gears and limited slip and I was wonting to step up to 373s a buddy of mine said that I could only go up to 308 is this true
Car: 1990 camaro RS
Engine: 305 TBI
Re: 273-373 Gears
yea they use different carriers i think theres some adapter to go to 3 series from a 2 series but from what ive heard the time and money to get the adapter thing to work your better of just buying a 3 series rear end
Engine: LQ4 ls 6.0
Re: 273-373 Gears
So does that mean that I will need a new rear end as well
Car: 1990 camaro RS
Engine: 305 TBI
Re: 273-373 Gears
yea imo just try to find one of the factory 3.73s might take a while but in the long run will be cheaper and much easier swap. you can Google 2 series carrier with 3 series gears to try to see what you need to do, ive never done it just heard my friend complain about it for ever when he did it lol
Engine: LQ4 ls 6.0
Re: 273-373 Gears
Ok so I need to find a carrier and gears and i should be set is that right
Car: 1990 camaro RS
Engine: 305 TBI
Re: 273-373 Gears
im not 100% sure if u can swap the carrier into the Axel or if you need an adapeter to do it thats why im saying check google
Car: 1991 pontiac firebird,
Engine: 305 tbi
Axle/Gears: eaton trutrac 3.73 gears
Re: 273-373 Gears
i have 3.73 gears in my rear end,the housing is stock 91 firebird with some brake components from an 87ta, there was no real problem but a little research wont hurt...good luck
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 273-373 Gears
From the ratios you discuss, I'm assuming you have a 10-bolt. The following may be helpful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
JamesC
UltRoadWarrior9
Sep 2, 2015 08:24 PM
