Throttle Return?
Old Dec 29, 2010 | 03:20 PM
nezzie09's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 2.8 MPFI
Transmission: 5-Speed Standard
Throttle Return?
I was wondering if anyone could tell me where to get what i believe would be a simple spring? Maybe not. But it's for my gas pedal. Problem is when i let off the gas, in neutral or gear, the throttle doesn't close all the way. I have to put my foot under the pedal and lift otherwise I sit at a red light burning gas.
Thanks.
Old Dec 29, 2010 | 03:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Throttle Return?
Springs don't usually fail that way. Can you push the arm on the throttle body closed with your finger to make the idle go down? Does it stick when the car isn't running? Have you tried cleaning the throttle body?
Old Dec 29, 2010 | 03:30 PM
nezzie09's Avatar
Engine: 2.8 MPFI
Throttle body was cleaned a little while ago(few months). Pushing the arm doesn't change idle speed, just opens and closes throttle body, when fully closed it is at idle:S
And I believe it sticks when off too, I'll go double check.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
DiabloWS6
20
Dec 11, 2015 04:12 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Randomtask2
Sep 7, 2015 05:06 PM
