Harmonic Dampners
Old Dec 29, 2010 | 08:29 PM
chevyracer8262's Avatar
Harmonic Dampners
I know my question is not thridgen related but can someone please help he me anyway. I know there's alot of you guy running 305s and here's delima I have at the monent.
I'm working on installing a 87 montie carlo 305 into my full size 88 GMC truck. The guy I got the engine from had removed the harmonic dampner from it and forgot to give it to me when I got the engine. Here's my question why did GM use 2 different thickness dampners on their 305's and are they compatable? The one that came on the engine was 2 1/2" thick but my truck has a 3/4" thick dampner and would like to know if I can use it. I know the 305's are internally balanced.
Thanks,
Old Dec 29, 2010 | 08:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Harmonic Dampners
Are the diameters the same?
Old Dec 29, 2010 | 09:54 PM
yes they are but the timing tabs in a different location but i do however have the matching timing cover and tab from the truck as well.
Old Dec 29, 2010 | 10:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Any of the balancers (except from a 400) will interchange across any of the engines (except the 400) as long as you're mindful of the differences in diameter and timing mark location.
Magman
Sep 13, 2015 12:14 AM
gixxer92
Sep 1, 2015 04:32 PM
Eric2ndGen
Aug 31, 2015 12:33 AM
theshackle
Aug 22, 2015 06:52 PM
Doug E
Apr 10, 2001 04:40 PM
