HELP!!! 2.8 gas in crankcase
Old Jan 8, 2011 | 06:24 PM
whiteboycv67's Avatar
Car: 90 Firebid
Engine: 3.1
Axle/Gears: 10 bolt posi w/4.11s
i have a 2.8 v6 in an s10 carbd im getting gas in the crankcase lots fuel pressure is at 5 psi i need all the suggestions i can get im tryin to fix this by tomorrow ??
Old Jan 8, 2011 | 06:42 PM
Re: HELP!!! 2.8 gas in crankcase
I'm guessing that motor has a block-mounted fuel pump? (don't know, haven't ever looked at one, every time I see one I avert my eyes in shame)
If it does, it needs a new fuel pump. The rubber diaphragm in those has pressurized fuel on one side, and crankcase on the other; so if the rubber breaks, guess what.
See my signature for a helpful hint about logic in general, which applies to this situation.
Old Jan 8, 2011 | 06:47 PM
Car: 90 Firebid
Engine: 3.1
its converted to electric with a block off plate do you think adjusting the float and putting hotter plugs in will solve it or is there other things i should look at ?
Old Jan 8, 2011 | 06:52 PM
Might solve it by exploding it; won't stop the fuel from getting in there.
Interesting how a little history helps shine some light on the cause of things, isn't it?
Most likely you have too much fuel pressure. I don't know much about those carbs, except that they're a total steaming bucket of sewage; but that'd be the first place I'd start.
After changing the oil of course, so that the motor doesn't explode. That kind of makes a mess. Oil goes everywhere, and then you have to pull it and change out all the sheet metal parts. At least, I'm guessing one of those has sheet metal? (oil pan, valve covers, and such as that) I don't really know.
Old Jan 8, 2011 | 06:55 PM
Car: 90 Firebid
Engine: 3.1
can some one give me some helpful advice please
Old Jan 9, 2011 | 02:51 PM
Set your regulator to a lower pressure.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
rjcme
Sep 5, 2015 01:23 PM
