Ignition Module
Old Jan 10, 2011 | 12:13 PM
RagRoc's Avatar
Car: 88 IROC Convertible
Transmission: M5
Axle/Gears: 9-bolt 3.45
Ignition Module
After my 89 RS with 305 and TBI sits idle for several weeks the ignition module burns out.
Background: I purchased the car from the second owner 18 months ago with a bad distributor (the car would shut off when warm due to massive timing fluctuation). The distrubutor has been replaced with new, and the car driven over 3,000 miles to Ohio and Atlanta without problems. The car has no wiring butchering, and a fourth gen camaro AM/FM/CD player. The battery holds a charge. The coil appears to be original.
The car fires right up after the module is replaced.......and yes I'm using the correct amount of dielectric grease under it.
This is my fourth replacement module. Any ideas?
Old Jan 11, 2011 | 12:31 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Foiled By The Coil
Replace that 23 year old coil.
If the primary has a partial short that will take out the module.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Jan 11, 2011 | 01:22 PM
RagRoc's Avatar
Transmission: M5
Re: Ignition Module
I'll do that tonight. Thanks for the response!
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
