gas in plenum brake booster?
Old Jan 11, 2011 | 05:19 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
i was thinking a hole in the diaphragm of the fuel pressure regulator.. i cant test for pressure drop because the hose in the tank is leaking so the pressure just drops.. im going to vacuum test the FPR and possibly narrow it down to stuck injector because i do get a slight miss when accelerating but it goes away sometime.. damn two stroke oil gas from last month i bet grrr..i just built a moped too. haha
Old Jan 11, 2011 | 05:58 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: gas in plenum brake booster?
To test for a broken regulator diaphram, just remove the vacuum hose from the regulator with the engine running. If the diaphram is broken, fuel will run out of the vacuum port.
Old Jan 11, 2011 | 06:24 PM
MAN!!! that sucks. YEAH it is the diaphragm. ughh...no wonder my gas milage is shitty... damn it. i have to remove the plenum and fuel rails now huh.. so o-rings plenum gaskets what else..gaskets do i need. i built a moped but no handle bars ugh.
Old Jan 11, 2011 | 06:38 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
You'll need runner gaskets and a fuel pressure regulator diaphram. Don't stress, the job isn't that bad. Just loosen the runner attaching bolts at the lower intake. Then remove the runner to plenum bolts and lift the plenum out. Be sure to disconnect all wirng and vacuum lines as you go. The MAT sensor is on the bottom of the plenum and you want to be sure you get it plugged back in before you bolt up the plenum. The diaphram is held to the regulator by six screws. Remove the screws and diaphram. With the plenum off, remove the runner to lower intake bolts and replace the gaskets. Then reverse procedure to reassemble.
Old Jan 11, 2011 | 06:44 PM
i need the size for the torx bolt head for plenum
Old Jan 11, 2011 | 08:18 PM
deleted
Old Jan 11, 2011 | 11:13 PM
deleted post
Old Jan 11, 2011 | 11:17 PM
after minutes of searching i guess t-40 is the right size. laters
Old Jan 12, 2011 | 12:58 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
T-40 is right and for the regulator bolts its a t-10 tamper
Old Jan 12, 2011 | 09:17 AM
well i replaced it last night, it works
Attached Thumbnails gas in plenum brake booster?-456.png   gas in plenum brake booster?-4567.png   gas in plenum brake booster?-45678.png
Old Jan 12, 2011 | 01:12 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
LOL. Thanks for the props man. It makes feel all warm and fuzzy. I see you took a short cut on the lower runner gaskets. Its okay though. Im sure they're fine. You can pull the plenum without loosening the lower runner to manifold bolts. I just like to reseal everything while Im in there. Good job and happy motoring.
Old Mar 2, 2011 | 03:12 PM
jeremymsl's Avatar
Car: 89 Iroc z camaro
Axle/Gears: stock
Ok i read this and im kinda a newb so i halfway understood all that haha, so im getting horribal mpg and i cant figure it out so i wanna know what hose to do to test this? like i need it in very basic terms haha
1992 Trans Am
May 10, 2023 07:19 PM
johanlindgren
Aug 16, 2015 12:16 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
