Weird squealing sound
Old Jan 15, 2011 | 07:25 PM
camaroman91's Avatar
Car: 91 Camaro RS
Engine: 350 carb'd
Ok so ever sense I bought this car its made this weird squealing sound and im not sure whats causing it. It seems to be comeing from the waterpump area. It sounds like a belt squealing so I sprayed some belt conditioner on the pullies and it didn't effect it. The weird thing is the sound only starts after the engine is warmed up a little. Its the wrong format for this site so I uploaded a sample of the sound here: http://www.mediafire.com/?7tths882vrtvkht let me know if you have any ideas please
-Thanks-
Old Jan 15, 2011 | 07:34 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Re: Weird squealing sound
check your power steering fluid and your coolant level (check that the radiator is completely full at the cap not the reserve tank.)
Old Jan 15, 2011 | 07:44 PM
Car: 91 Camaro RS
Engine: 350 carb'd
yea I checked all of the fluid levels and if it was a problem with the power steering wouldn't the noise change or increase when the wheel was turned?
Old Jan 15, 2011 | 07:54 PM
Red 87 GTA's Avatar
not necessarily, the pump may work but be dangerously low on fluid so i would just check it to be sure. most systems leak very very slowly over the years and its normal
Old Jan 15, 2011 | 08:10 PM
Car: 91 Camaro RS
Engine: 350 carb'd
ok I wasn't sure about the noise thing. But yea the fluids good its made the noise for awhile with no known side effects, none that i've noticed anyways
Old Jan 16, 2011 | 12:58 PM
Red 87 GTA's Avatar
change all your belts then and hopefully its not your water pump. if you change them and the noise continues check your pump. hope this helps
Old Jan 16, 2011 | 02:55 PM
Car: 91 Camaro RS
Engine: 350 carb'd
I thought it was the best at first so i pulled it off and checked it over real and its not dry rotted at all and looks good so I don't think its the belt. But it very well could be the water pump I will look into getting a new one to try out. Thanks for all your advice
Old Jan 16, 2011 | 03:05 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
take the belt of and start the car doe sit still make the noise? Not long just enough to see if its making noise!!!!
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
