5.7 L98 REAR SPARK PLUGS. HOW DO I REACH THEM??
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
WHATS THE TRIK TO REACHING THE REAR SPARK PLUGS ON 1988 L98 5.7 ?? ENGINE PULL ? TRANS DROP ? ? ?
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
Re: 5.7 L98 REAR SPARK PLUGS. HOW DO I REACH THEM??
offset handle ratchet helps, but from under the car is what I do
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
I get the back two from underneath. It's a pain in the a$$...
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
They can be done from the top with a swivel ratchet, a solid ratchet and the right combination of sockets and extensions. IIRC, I use a straight, non universal, socket with a 1" extension and swivel ratchet on the passenger side to clear the AC housing. On the driver's side, I use a universal socket and whichever extension works. To avoid broken knuckles, dont use universal sockets with a swivel ratchet. I use Snap On tools which allow the best clearance.
GONNA TRY TO GET THE BACK 2 PLUGS FROM UNDERNEATH THE CAR. A/C HOUSING CLEARANCE IS XTREMELY TIGHT ON THE PSSNGR SIDE.
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
is ur CAPS button stuck on? or do u just injoy typing like that lol.. underneath would be the easy way to get them
Also, please turn off the Caps Lock key. It's poor netiquette, it's like you are yelling all the time.
1992 Trans Am
May 10, 2023 07:19 PM
