Smell of Gasoline? Need new gas tank?
Old Jan 17, 2011 | 05:28 PM
84CAMARO28inFL's Avatar
I smelled gasoline the day after i added Gas in the tank. Neighbor says it smelled very strong this morning, im thinking there is a probable leak.
Will a 1991 Fuel Injected gas tank work on the carburated one? Im also getting pressure test and seeing what i can do for the smoke or steam i saw when i had the radiator cap on.
How much does getting a new gas tank cost?
Old Jan 17, 2011 | 06:35 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Smell of Gasoline? Need new gas tank?
check places like rock auto, or gmpartsdirect.com
or call your local auto parts store.
I would imagine 100-200 dollars.
before you change the tank, make sure your gas cap isnt 20 years old with a crusty o-ring seal.
also, I believe all thirdgens have that vent under the gas tank on the drivers side by the brake line junction from body to axle. replace that too.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Bohemian
Aug 15, 2017 05:11 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
