Serp setup bracket questions
Old Jan 24, 2011 | 07:13 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
The black brackets, one runs from my alternator to my intake, the other from my A/C pump to my exhaust manifold..
Do I need these? My air gap intake won't allow the one for the alternator, and my headers are too spaced out for the one on the A/C pump (delete)..
Old Jan 24, 2011 | 08:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Serp setup bracket questions
On the headers, we usually go to Home Depot, they sell a metal sleeve in the nut/bolt drawers for $1 that is about 1.5 inches long - it's perfect for mounting the A/C bar where the header bolt goes - just get a longer bolt for that hole (or use the old manifold stud that was a bolt with a screw on the top kinda).
The alternator I think will be fine - it's more of a try it and see deal - if the belty squeeks bad and starts to wear, then you'll need to fab something - but I think most folks get away without it as it doesn't have the pressure on it that the A/C gets (takes alot more force when the A/C clutch engages, thus more twisting pressure is applied).
Hope that makes sense.
Old Jan 25, 2011 | 06:18 AM
Kevman's Avatar
Engine: 2004 LQ4
I'm using the A/C Delete pulley, so there's no resistance at all.
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
