IAC or TPS?
Old Jan 25, 2011 | 08:24 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
IAC or TPS?
these two are my guesses heres what my cars doing. at start up vacuum leak sound through my throttle body what is that? when i decelerate to a stop the car enjoys stalling and also when sitting for periods of time with light throttle usage IE drive throughs. so after speaking with some members as well as reading posts i believe i have it narrowed down just seeing if anyone else has had this problem and found the solution so i dont have to the hard way.
Old Jan 25, 2011 | 09:17 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: IAC or TPS?
The computers are pretty smart and can normally pic up on it when those kind of items are bad.
Do you have a service engine light on? Check for stored codes?
Old Jan 25, 2011 | 09:42 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: IAC or TPS?
yeah i guess i need to do that and yeah i do have a service engine light at all times. how many times will the code flash before moving on to a new code if there are multiples?
Old Jan 25, 2011 | 10:27 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: IAC or TPS?
Service engine light is good then. Its going to help you with the problem. Don't disconnect the battery or pull any fuses until you check the code(s).
All codes will flash three times before moving to the next.
First you will see is 12, distributor reference. You get that always because the engine is not running. It also lets you know that your jumper wire to the ALDL is got connection!
Code 12 three times and then the next code three times and so on until you see code 12 again and that is the process starting over.
Go check codes and get back here. I'm waiting...............
Old Jan 26, 2011 | 05:46 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: IAC or TPS?
got em checked and at first i had 8 codes lol 13 15 22 23 24 32 and a couple others that were in the 40's or 50's. i disconnected the battery and drove to my parents house. this gave the ses light time to respond. i checked it again when i got there and all i threw was a code 15 so my temp sensor is bad? however during this drive the car did not stall meaning neither the tps or the IAC would have failed. i did fix the intake leak my tbi gasket was awful i replaced it and it stops that hissing at cold start up.
Old Jan 26, 2011 | 05:52 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: IAC or TPS?
Well there you have it. Check the wires and plug and if they look fine replace the temp sensor. Cheap, easy and imporatnt as that tells the ECM the engine temp so if its wrong it can play games with you.
You do know that the temp sensor is located in the intake.(not the one in the heads) Has a yellow wire and a black wire.
Old Jan 26, 2011 | 07:39 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: IAC or TPS?
yeah ill check it out and my temp gauge does work seemingly accurate but yeah i'll definitely take a look at it. and no i wasn't exactly sure but im sure i would of as soon as i looked for it. but thanks that makes it a little more reassuring
Old Jan 28, 2011 | 12:22 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: IAC or TPS?
http://www.gmtuners.com/OBD1_DTC.htm Those are the codes for gm obd1
Old Jan 30, 2011 | 08:25 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: IAC or TPS?
so low and behold i changed the temp sensor and my car hasnt stalled since and that was done on thursday.
Old Jan 30, 2011 | 08:30 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: IAC or TPS?
COOL!
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
