Looking for some advice...
Old Jan 28, 2011 | 01:54 PM
5 'O THIS's Avatar
Car: 1985 Z-28
Engine: 355 cid
Okay, I'm in need of some help from people a little more tech savvy than I am! I've got a stock bottom end 350 in my 85-Z, the motor has been completely rebuilt and has about 2,000 miles on it. Problem is, every time even since the first time firing it up it likes to smoke. At idle, while driving...pretty much all the time.
Where should I start? Compression test?
Old Jan 28, 2011 | 03:14 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: Looking for some advise...
A compression test would be a good Idea it could be a ring that is failing to seat.
as you only mention the bottom end and nothing about the heads are they new or rebuilt it could be bad valve guides or seals also.
Is the smoke white or does it have a blueish color to it?
Old Jan 28, 2011 | 04:18 PM
5 'O THIS's Avatar
Car: 1985 Z-28
Engine: 355 cid
Well, I put a set of "cleaned up" camel hump heads on it. Single plane intake, 750DP Holley, and a Comp grind with ".490 lift.
The smoke is kind of bluish, the only think I have ruled out is the carb. I'm hoping it's not the rings, don't want to have to pull the motor.
Old Jan 28, 2011 | 05:17 PM
HF_monster's Avatar
Transmission: th350
you can check them with a dual gage leakdown tester, but to start off take the valve covers off and see if you have play in the valve guides by trying to move the valve stems back and forth. check the condition of the valve seals. pull the plugs and see if one is oil soaked or wet with gas. if the oil smells like gas you could be running too rich and that can cause the rings not to seal letting oil by.
Old Jan 28, 2011 | 09:23 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Looking for some advice...
May be sucking oil past the intake gaskets.
TipTricky
Jul 2, 2014 10:02 PM
Sinfulrelations
Jul 11, 2013 05:36 AM
t top
Apr 21, 2013 11:54 AM
Ultra103
Jan 2, 2013 03:38 PM
irocdls1
Sep 13, 2012 05:04 AM
