What is this gold thing its in the way of my new carb
Old Feb 2, 2011 | 03:55 PM
z28breh's Avatar
Car: 1987 camaro Z28
Engine: 305 4bll
I got a new edelbrock performer series carb, i tried to put it on but this thing is in the way i have no idea what it is and my haynes manual doesn't tell me
Its the faded gold thing to the left of the carburetor adapter.
1. what is it
2.can i take it off
Thankyou
Old Feb 2, 2011 | 03:59 PM
chris lo's Avatar
Car: 92 z28 vert
Engine: ls6
Transmission: t56 magnum
Axle/Gears: moser 9 inch 4.11
Re: What is this gold thing its in the way of my new carb
its the egr valve
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
its the EGR valve you can get a blockoff plate at almost any auto parts store. getting rid of the CCC carb you need to change the dist. also to a vacuum advance early style to avoid the computer from adjusting the timing.
Old Feb 2, 2011 | 04:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
And you need to deal with the computer not locking the TCC and check the TV cable geometry.
Old Feb 2, 2011 | 04:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
on the distributor.
You also have to get a geometry corrector for the TV cable - it attaches to the linkage on the carb and the TV cable attaches to it.
And you'll need a method of locking the torque converter since the computer is now gone.
Old Feb 2, 2011 | 04:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The squarebore carb to spreadbore manifold adapter is a bit of a performance killer, too.
Old Feb 2, 2011 | 04:15 PM
z28breh's Avatar
Engine: 305 4bll
wait i need a new distributor?
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Absolutely
Old Feb 2, 2011 | 04:21 PM
z28breh's Avatar
Engine: 305 4bll
so what are all the parts i need and there costs
thankyou for your help i need this car running to get to work
Old Feb 2, 2011 | 04:29 PM
Car: 1992 RS
Engine: Carbed 350
1) Vacuum advanced HEI distributor and coil $125
2) Geometry corrector for TV cable $20
3) Method of locking torque converter - free to $125+ - depends on what method you choose https://www.thirdgen.org/forums/carb...c-control.html
4) EGR blockoff plate $20
Your car is computer controlled - it gets inputs from the carb, the exhaust, the engine, and changes fuel mixtures and timing, locks/unlocks torque converter, etc. and thus is getting 'tuned' on the fly. You cannot just slap any aftermarket carb on the top and keep going. All the computer-related items need swapped out or deleted as well.
Then all the new non-computerized stuff needs tuned - timing needs set, carb needs adjusted, etc.
This is not an overnight project.
Old Feb 2, 2011 | 04:34 PM
Car: 1992 RS
Engine: Carbed 350
Also - if this car was carbed before with a factory carb, you're taking a step backwards in performance and mileage - you can't beat the factory carb setup.
Old Feb 2, 2011 | 04:56 PM
Car: 1992 RS
Engine: Carbed 350
Morrisville, as in Raleigh area? I'm in Cary myself - be glad to come help if I can!
Old Feb 2, 2011 | 08:13 PM
z28breh's Avatar
Engine: 305 4bll
yeah i live in morrisville and thankyou! haha hopefully i dont need any help though,
i have a question though before i spend more money trying to put in this carb, which you say will rob power where can i get a rebuilt one or refurbished one cheap, i have the original one still its a 1987 4bll and by what everyone is saying it seems like a better idea to stick to the original
Old Feb 2, 2011 | 11:07 PM
HF_monster's Avatar
Transmission: th350
you can get a rebuild kit for about 15-25 bucks at your local parts store it dosent take long to rebuild I did 2 in 4 hours thats removal from the car and reinstall. just note all the settings when you break the carb down (idle screws turns from seat are about the only thing if you do a basic rebuild).
Old Feb 3, 2011 | 06:36 AM
z28breh's Avatar
Engine: 305 4bll
Thankyou i got the haynes manual so i think rebuilding shouldn't be to difficult
midge54
Dec 27, 2019 04:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
87yellowirocz
Exterior Parts Wanted
Oct 23, 2015 09:52 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Bob88GTA
Aug 18, 2015 03:31 PM
