Hi all and an 83 Camaro electric window problem
Old Feb 2, 2011 | 08:55 PM
Gus58's Avatar
Hi new here, I just bought an 83 iroc, its not in too bad a nick, but I can see myself asking a few questions here, Its been converted to RH drive for australian conditions and has a non standard 350 motor with a 3 speed auto. I went to wind the LH window up and it doesn't work, it was working when i bought it. I have pulled the door skin off (well nearly, the top is stuck) unclipped the wires to the window motor, put a multimeter on them, yep power to both, my question, is this a sure sign that the motor is blown, or maybe some sort of limit switch may be broken, If the motor is blown, whats the best way to get the old one out? Are there any dangers to watch for like spring loaded levers or similar? thx Gus
Old Feb 2, 2011 | 11:22 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: Hi all and an 83 Camaro electric window problem
nothing too bad the motor is rivited to the regulator you need to have the window about half way up to remove it from the tracts. if you just need to get it to roll up you can try hitting the motor with a shot of brake or carb cleaner sometimes it works. For getting the interior panel off once you get the clips off the inside take a long screwdriver to lift up on the plastic on top it has clips that hold it to the window opening.
and welcome to the board.
Old Feb 2, 2011 | 11:44 PM
Gus58's Avatar
Ok thanks for the info and welcome, yeah the window is down, it might be a battle.... but hopefully i'll get it......
Old Feb 3, 2011 | 06:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by Gus58
Hi new here, I just bought an 83 iroc...
Hey, Gus, welcome to TGO. There aren't many questions that haven't been asked and answered, so a search on site is generally a good idea.
BTW, the first year for the IROC was 85.
Good luck with your project.
JamesC
Old Feb 3, 2011 | 10:04 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Here's a great thread on window motor replacement, and includes a printable template:
https://www.thirdgen.org/forums/body...tall-easy.html
And another article on door innards in general with pics:
https://www.thirdgen.org/forums/body...servation.html
Old Feb 3, 2011 | 10:54 PM
Gus58's Avatar
85 hey????? well mines rego'd as an 83 with Iroc badges??????? maybe the chassis number off the last pic may help..... Thanx for the help so far, appreciated.....
Old Feb 4, 2011 | 06:43 AM
JamesC's Avatar
The third brake light and the taillights themselves are not from an 83. Nor are the IROC-Z emblems. All, however, are consistent with an 88, to include yellow paint. I'm not a vin expert by any means, but a vin "C" would appear to make the car an 82. (FWIW, yellow wasn't offered in 82 or 83.) Curiouser and curiouser, said Alice, because an 88 wouldn't have been originally equipped with an H motor (LG4 carbed), but an 82 or 83 would have been. My guess? Clone.
1 USA
G Gen motors
1 Chevy
A Restraint system
P Car line series
87 Body type
H Engine type and make
6 Check digit
C Model year
L Assembly plant
144318 Plant sequential number
You may find the following, concerning IROC identification, interesting:
https://www.thirdgen.org/forums/hist...-car-iroc.html
JamesC
Old Feb 4, 2011 | 07:13 PM
Gus58's Avatar
ahh the yellow paint is a respray, was a dark orange from the looks of it
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
