Climate Control Fan
Old Feb 3, 2011 | 05:14 PM
musclecars90's Avatar
Car: 1986 Iroc Camaro
Engine: 305 5.0L
Transmission: 700 R4
Climate Control Fan
On my camaro my fan for the AC and the Heater works on all the setting except Hi. I figure there's a bad vacuum line some where. Any ideas of finding the problem.
Old Feb 3, 2011 | 05:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Climate Control Fan
I think HIGH is controlled by the relay - it should be attached on or near the heater box under the hood. The resistor that is attached in the heater box controls the lower speeds. Vacuum leaks tend to make the air blow only out the defrost vents, and don't have anything to do with the speed of the fan motor.
Old Feb 3, 2011 | 05:43 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Loss of high speed fan function can be caused by a blown fuse link. Does your underhood light work? If not, check for power at the inline fuse to the underhood light. If no power, look for fuse link B to be broken.
Old Feb 3, 2011 | 06:36 PM
Engine: 305 5.0L
Well i got my fan working I had power to all the RED and the Orange wire so it had me stumped. The relay was replaced before and the person before me just wrapped wires and electric taped them so that was like a WOW. Some of them were corroded so I cut them back and soldered them and now it works. Now I did something when I took my interior out and only the defroster works so back to trying to figure out whats wrong
Old Feb 3, 2011 | 06:40 PM
Car: 1992 RS
Engine: Carbed 350
If only blowing at defroster vents, that's a vacuum issue - might have a vacuum line on the back of the heater controls come loose or sprung a leak.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
formula1LE
Sep 12, 2015 08:31 PM
scottmoyer
Sep 7, 2015 07:06 PM
85Special
Sep 3, 2015 04:21 PM
