intermitiant stalling when stopped
Car: 1989 Camaro IROC-Z
Engine: LB9
Axle/Gears: 3.08 G80
was drivin today, and my camaro stalls like 1 outta 6 times whenever you come to a complete stop. its a lo3 minus AIR tubing (still havent pulled teh pump) and it has a new open element air cleaner. should i clean my egr and injectors? it has a fresh tune up.
Engine: LS1, LB9, L03
Re: intermitiant stalling when stopped
I would start with cleaning or replacing the EGR if you haven't done it recently.
Engine: LB9
well ill clean the EGR, IAC, and TBI, and see if that helps any. i do have a code 54 for hte EGR, so hopefully that fixes it
