Wiper motor
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Wiper motor
I am trying to find out if my wiper motor is bad and I need to know witch wire do I test to see if I am getting power to the motor? it is a 91 firebird
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Wiper motor
Wiring diags here for almost every 3rd gen - any of the 1992 wiring guides (alot of them farther down the page) will apply to your 1991 car:
http://www.austinthirdgen.org/index.php?pid=19
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Re: Wiper motor
Good rule of thumb that usually holds true for 3rd gens is red = hot at all times, pink = hot in run and start, brown = hot in run. Other colors tend to be specific application like sensor wires or function triggers.
Engine: LQ4 ls 6.0
Re: Wiper motor
Ok so witch should I test to see if I have a bad motor? there are 6 wires on the motor
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Rain Pain
Open the wiper motor unit.
Apply 12 volts to the purple wire.
If the motor is good it will run.
Happy Racing!
How bout those too scared to drive without headlights in the daytime
and the ones that need headlights for a little rain
Happy Racing!
